HP3 error 50
  • Mr. Higgans
    HP3 error 50
    I have an HP III with an error 50, it started after I installed a new cartridge. It\'s basically a back-up printer, is it worth fixing?
  • protec
    Re:HP3 error 50
    Error 50 is a fuser error. If you can\\\'t clear the error by disconnecting from power source then reconnecting , you will probably be spending around 200 bucks to replace the fuser(not including labor if you aren\'t tech-like) Your choice.
    • John T
      Re:HP3 error 50
      If you are not a tech, call one. This can be fixed for less than $200 with a rebuilt fuser. The 3 is a good horse, I have let one die after more problems than the fuser. It sitting in the parts locker if you want to steal it.
