HP 2840 cartridge problem
  • hmac
    • Aug 2009
    • 129
    Hello,
    I have a HP 2840 with two problems:
    - At the beginning, there was no black ink on the copies.
    So I remove cartridges to clean and have a look, but now:
    - Impossible to put the cartridges, turn the cartridge block is not correctly placed in front of the holes for the cartridges.
    Do you have any idea what is urgent?
    Thank you and good day
    _________________
    HMac.
    _________________
  • Wild Bill
    • Jul 2005
    • 774
    Re: HP 2840 cartridge problem
    Need to perform Carousel Indexing Procedure / check
    Also possible the carousel solenoid felt is old and sticking.
    Izzy
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • prntrfxr
        • 1622
        See attachment for carousel alignment procedure:
        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
        • mjunkaged
          • 386
          There is a way to 'cheat' and not do an entire carousel disassembly. However, the risk is that you can break the large plastic gears on either side, then you WILL have to remove/repair.
          See youtube. Search for it. IT WORKS!! SAVE TIME!
          • prntrfxr
            • 1622
            My opinion is take the time to do it right the first time (It's not that bad to take the covers off.), then you don't have to do it twice. But that's just me. If it works for you, more power to you. Damage the carousel, however is rendering the printer useless (which it pretty much is anyway) as it will not be cost effective to repair.
            • Wild Bill
              • Jul 2005
              • 774
              First check the alignment. If its on, then it's the solenoid.
              Izzy
