HP 4345mfp Consistent 13.02 paper jam
  • yormets
    • May 2009
    • 336
    This 4345 with 150K on it will throw a paper stopped error in the upper print area. It is always in the same place, same error code. It will run smoothly for 10-15 prints and then jam. There is paper halfway through the fuser, and about two inches of blank paper coming out of the registration unit. The jam is always exactly the same. We have blown out all the sensors, changed fuser assy, changed duplex unit and all feed and separation rollers. Nothing matters. We've done the manual sensor test, everything is fine. All sensors work correctly....until you run it. Does anyone have any idea what this could be? I'm stumped.
  • JustManuals
    • Jan 2006
    • 9838
    Re: HP 4345mfp Consistent 13.02 paper jam
    Paul@justmanuals.com
    • prntrfxr
      • 1622
      Reversing-Separation Guide?
      Reversing Assembly?
      Registration Assembly?
      Did you check behind the Tray 1 P/U asm for labels/debris that may be slowing down paper movement?
      Did you change the toner cartridge?
      • CRam007
        this error 13.02.00 refert to the media did not arrive at the top-of-page sensor (PS103) on the specified time. how many trays do you have? is this error on the tray 1? 2? did you check for any piece of paper on the paper path?
