Hp Color Laserjet 5550
  • Dimpo
    • Aug 2009
    • 104
    [Dead] Hp Color Laserjet 5550
    Hi
    I have an Hp Color Laserjet 5550 not printing color.If i print supplies page it shows that Magenta and Cyan are missing,they are not there completly but it will be showing 75% full.I have opened the machine and serviced it , i even take out the four scaners and cleaned them but still doing the same.
    Have someone once came across this problem and how did you solve the problem?Please help am stack i desperately need your help.
    Hope to hear from you soon
    Best Regards
    Dimpo
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    Re: Hp Color Laserjet 5550
    Are the cartridges Hp, or re-manufactured?
    • Dimpo
      • Aug 2009
      • 104
      Cartidges are originals and they are all new
      • JustManuals
        • Jan 2006
        • 9838
        This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
        Paul@justmanuals.com
        • HP:guy
          • Feb 2013
          • 279
          Poor contact exists in the
          primary charging bias or
          developing bias contacts
          between the print cartridge
          and the product.
          Clean each contact of the color that
          produces the missing color. If the
          problem remains after cleaning,
          check the contacts for damage.
          Replace any deformed or damaged
          parts.
          The print cartridge (primary
          charging roller, developing
          roller, or photosensitive drum)
          is defective.
          Replace the print cartridge of the
          color that matches the defect.
          The imaging high-voltage
          power-supply is defective (no
          developing bias output).
          Replace the imaging high-voltage
          power-supply.
          The laser/scanner unit is
          defective.
          Replace the laser/scanner assembly.
          • Iowatech
            Not a service manager
            • 3930
            HP guy has the instructions to follow. However, what kind of environment is that machine in? I've got some machines out on factory floors, and if that machine is in a similarly awful environment you might try cleaning the laser unit if time allows. If you aren't dealing with an actual laser diode or polygon mirror motor failure, that might buy you some time until the new laser unit arrives. Or it might break the laser unit completely, so proceed carefully.
