HP LJ 2100tn PJL Service Mode Commands
  • techathens
    • 83
    Hello all,
    I have a client with many retail outlets that are still using the HP LaserJet 2100tn. The problem is many of the 2100tn's have had the users tray setting changed back to the default settings and these units are deployed all over the network / storewide via HP JetDirect network cards - meaning someone at the corporate offices in Norcross GA can send a job or message to a printer in Charlotte NC (etc), if needed.
    Thanks in advance!
    Salesout Pro
    SalesoutPro@gmail.com
    • 23010
    All my experience with PJL Printer Job Language has been from cutting & pasting little bits of code from data captures into other data captures to to add functionality. For example adding job accounting codes, paper size designations, tray selections, etc.
    If you had said PostScript, PreScribe, or PCL Printer Control Language, I have manuals for those. But not PJL.
    I just found this on the net: http://h20000.www2.hp.com/bc/docs/su...8/bpl13208.pdf
    Good luck and let us know how it goes.
    Last edited by blackcat4866; 04-26-2008, 02:39 AM. Reason: would not attach the PJL manual, only 2MB?
    • techathens
      • 83
      Hey Black Cat,
      Thanks for the link to the manual.
      Salesout Pro
      • JustManuals
        • Jan 2006
        • 9838
        That is only the first part of the manual. There is a 2nd part as well.
        Paul@justmanuals.com
        • techathens
          • 83
          Thanks for the information - the problem on this HP LJ 2100 turned out to be board related, not the PJL Service Mode Commands. But I now know how to program and upload these commands.
          Salesout Pro
