CM3530 MP Tray Part?
  • Solotime
    • 223
    Have a customer with a CM3530. They broke the small tray that holds/guides the paper when feeding from the MP tray on the right side. This is a small tray with the pivot pins at the end and the small white wheels than run against the cams that lift this tray up and down when feeding. I can not seem to find a part number for this tray. Only the whole right side door that contains this tray. Is this part available separately or are they looking at having to order the whole door?
  • JustManuals
    • Jan 2006
    • 9838
    Re: CM3530 MP Tray Part?
    Paul@justmanuals.com
    • Iowatech
      Not a service manager
      • 3930
      Except for user replaceable stuff like feed rollers, HP parts come as assemblies. So you will have to order the entire door if that's the way it is listed.
      On the other hand, you might try posting your request here just to hedge your bets:
      The Parts Room
      • prntrfxr
        • 1622
        The whole door
        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
