HP Color LJ4600 pulling more then one sheet
  • copyman
    Owner / Technician
    • Sep 2005
    • 4708
    Machine will intermittently pull 2 sheets. For instance if you run 3 pages you will get 4 pages with one being blank. It prints the complete job. Doesn't happen all the time. The customer could live with this happening once in a while but presents a problem when they run checks, the blank check will throw all the check #'s out of sync.
    I have replace the feed rollers and cleaned everything. Unlike most HP's that use a Sep roller to stop double feeding this model uses the silver metal tabs on paper tray, I think these are only thing that seperate the pages when using the paper tray?
    Thanks for any help
  • JustManuals
    • Jan 2006
    • 9838
    Re: HP Color LJ4600 pulling more then one sheet
    Paul@justmanuals.com
    • HP:guy
      • Feb 2013
      • 279
      replace this sep pad RF5-3750-020.
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        You can get a refurb tray for about $60
