HI,
Im going to replace lift motor assembly on Monday(hope this is cause ),following the
steps in service manual seems to be a bit of a pain.Many times there are shortcuts and steps
that are not absolutely necessary.Is that the case with following procedure in HP service manual to replace lift motor assembly?Is a shorter way possible?
Thanks for any advice .ANDY
