HP CM1415 fnw blank display
  • ldfrepairs
    • Oct 2012
    • 148
    Powers up of but after display goes dark with question mark (?) in upper right hand corner of display
    drugstore-onlinecatalog.com
  • yourownfree
    • Dec 2007
    • 474
    Re: HP CM1415 fnw blank display
    check memory, I am guessing on this one. When I see a blank screen and the screen works I head for the memory then formatter. Is it possible a wire got pinched somewhere. will it still work even when the screen is blank. Now it could also be a power supply issue. and of course always check your power source for ground to neutral, unplug machine and then reboot.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • prntrfxr
        • 1622
        If it has a network card, HDD or other EIO device remove it and power up the printer again. See if the problem remains. If it does or the network port is built into the board, it is probably the formatter.
        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
