HP Color LaserJet 3000n Throwing a 13.20.00 randomly?
  • Kirkc
    • Apr 2012
    • 42
    [Jamming] HP Color LaserJet 3000n Throwing a 13.20.00 randomly?
    We have a HP Color LaserJet 3000n Throwing a 13.20.00 randomly on start-up the display says "13.20.00"
    On start up it releases the pressure on the fuser and when it clicks and pops open the top cover a little
    Right after it does this it throws the jam code?
    It sometimes does it and works fine until it wakes back up (after sleep mode) or you turn it off then on again
    What we Tried:
    Replace the whole fuser gear assembly (which is only all one unit)
    Replace with a New Fuser
    Replaced pressure sensor on the assembly
    Any ideas or anyone been having this issue?
  • JustManuals
    • Jan 2006
    • 9838
    Re: HP Color LaserJet 3000n Throwing a 13.20.00 randomly?
    Paul@justmanuals.com
    • Kirkc
      • Apr 2012
      • 42
      I have a Manual, Thats why im on here reaching out !
      • JustManuals
        • Jan 2006
        • 9838
        Well if you have the manual, then read it. The answer is there.
        • Wild Bill
          • Jul 2005
          • 774
          I have never seen that problem sorry, but i would upgrade or replace it
          You can find those 3000 series for very cheap right now, less than those parts you put in it.
          Izzy
          • wseyller
            • Sep 2012
            • 1129
            Then I guess every post on this forum is unnecessary except yours.
            Also manuals do not contain every answer. If they were perfect then manufacturers wouldn't have to ever make revisions to them nor would they have to create bulletins for newly found issues that are not covered in service manuals. Just my 2 cents.
            Sent from my Galaxy Nexus using Tapatalk 2
            • prntrfxr
              • 1622
              13.20 is a generic error that can be anywhere in the printer. Go to diagnostics and do a sensor test. Find out which sensor is giving the error and start from there (troubleshooting section of manual should walk you through it.
              Usually it is a bad fuser. Interior gear teeth break, pressure spring out of of position, or bad sensor. Cheap plastic so things break easy. Even OEM break in shipping.
              Check your event log for other errors
              Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
              • Kirkc
                • Apr 2012
                • 42
                I Now have a CP3505 doing pretty much the same thing it's making a grinding noise and then throwing the same code. I also still have the issue with the first one i posted doing the same thing! Help anyone Have any Ideas?
