HP LaserJet M4345mfp, scanning problems
  • aditaticu
    • Dec 2010
    • 7
    [Misc] HP LaserJet M4345mfp, scanning problems
    Home black and white scanned the network is ok, the second page is slightly paler.
    If the scan is in color, the first page is ok (blue writing on a white background), the second page is the reverse color (white lettering on a blue background).
    It may be of a formatter board? Or what?
    thanks.
    ADI
  • JustManuals
    • Jan 2006
    • 9838
    Re: HP LaserJet M4345mfp, scanning problems
    This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
    Paul@justmanuals.com
    • Iowatech
      Not a service manager
      • 3930
      If you haven't tried rebooting the machine you should try that first.
      You might also try changing the scanning output. And it sounds a tiny bit like you might have a corrupted or outdated program dealing with the scanned data right now, as I'm pretty sure a bad formatter can't cause color shifts like this. But I'm not totally sure, so take that with a grain of salt.
        • 23008
        What type of scanning are you doing? TWAIN, FTP, SMB, Email? =^..^=
        • aditaticu
          • Dec 2010
          • 7
          I attached two test pages. For privacy reasons we attached the first page of each.
          Scanning is done with the "Scan To Folder" from the printer
            • 23008
            Originally posted by aditaticu
            ... Scanning is done with the "Scan To Folder" from the printer ...
            That narrows it by half: Either SMB or FTP.
            And what scan settings?
            Have you tried altering the scan settings to see how it affects the images? Like DPI, Text-Text/Photo-Photo, compression, color versus monochrome, etc.
            • wseyller
              • Sep 2012
              • 1129
              Not saying I have the answer but in any situation like this where you get weird result I always make sure the firmware is the latest. I recently had a an issue with an HP multi function device that every so often would show the scan as a blank page when using HP scan software. Update firmware from a 2006 version to 2012 and the issue never returned. Just saying that it is easy to update and is a good to at least eliminate firmware.
              Sent from my DROID BIONIC using Tapatalk
              • wseyller
                • Sep 2012
                • 1129
                Originally posted by wseyller
                Not saying I have the answer but in any situation like this where you get weird result I always make sure the firmware is the latest. I recently had a an issue with an HP multi function device that every so often would show the scan as a blank page when using HP scan software. Update firmware from a 2006 version to 2012 and the issue never returned so far in the last month (crossing fingers) Just saying that it is easy to update and is a good to at least eliminate firmware.
