HP 4250TN running slow
  • yormets
    • May 2009
    • 336
    Anyone seen a 4250TN suddenly start running about half speed when printing? It's not the network as the customer has several printers and the problem follows this printer. I've checked the paper settings and changed the formatter. Same result. It warms up at normal speed, but prints slow. Any ideas?
  • HP:guy
    • Feb 2013
    • 279
    Re: HP 4250TN running slow
    What driver are you using?
    I recommend you use the PCL5.
    The PCL 6 and universal driver have a lot running in the back ground and will slow things down.
    • yormets
      • May 2009
      • 336
      I don't know. They have several printers. It only effects this one printer no matter what station they put it at. Same driver is driving all their printers. This one suddenly started running slow. It's not a network issue. It's in the printer.
      • HP:guy
        • Feb 2013
        • 279
        Then its time to upgrade firmware.
        • yormets
          • May 2009
          • 336
          Isn't the firmware in the formatter? The firmware upgrades the DC controller?
          • JustManuals
            • Jan 2006
            • 9838
            paul@justmanuals.com
            • Wild Bill
              • Jul 2005
              • 774
              Its may be set on custom blue lever on actual tray
              Izzy
              • HP:guy
                • Feb 2013
                • 279
                The firmware loads on to the format board.
                • tonerlungs
                  • Sep 2010
                  • 5
                  It is usually the custom lever in the tray not hitting the the switch correctly also check in the menu under print quality, fuser mode ,plain it is set to normal not heavy 2
                  • SOS
                    • Oct 2011
                    • 46
                    If you have second optional tray, try to remove away from machine and test
                    • draph
                      • 132
                      I saw this just recently. My problem child had 3 trays and it only did it from tray2. Tray 1 and 3 ran normal speed so that narrowed it down pretty simply. Swapped out tray 2 feed assembly and every one was happy.
                      Strange thing was it never jammed from tray two. Just ran at half speed.
                      • dreamz80
                        hi,
                        you need to cold reset the printer and restore to
                        factory setting...
                        thanks,
                        dreamz
                        • Blizzoo
                          • Aug 2013
                          • 610
                          Check if PS104 Output-bin-full sensor operates normaly.Had many times when the actuator of these was stuck and slow down printing.
                          LE : Didn't see that this is an outdated thread
                          • greenbean
                            Midwest Regional Manager
                            • Jun 2014
                            • 27
                            replace the fuser
