HP 4250dtn error
  • ldfrepairs
    • Oct 2012
    • 148
    HP 4250dtn error
    Getting error "processing job" displayed. Checked all printers on network and cannot find any jobs pending. Cancelled job on printer. Any suggestion?
    drugstore-onlinecatalog.com
  • micko_gm
    • May 2008
    • 18
    Re: HP 4250dtn error
    How do you connected to the printer (by network or usb cable)....try to change your connection,to isolate the problem..
    • riyadh_ksa
      You can remove the optional network card,and use Usb cable for testing....
      • HP:guy
        • Feb 2013
        • 279
        Upgrade your firmware.
        • yourownfree
          • Dec 2007
          • 474
          If it has an external jet direct card, take it out and reboot printer. did that cure it? Then your card is bad. Also if it is an embedded jet direct, meaning you cant loosen two screws and remove then you need to take other steps. Note this will erase your ip address in the printer. Perform a cold reset. You will not be able to update firmware if your printer is in error.
            • 23010
            The 4250 and 4350 with the embedded jetdirect will still accept the standard jetdirect cards. Its a cheaper solution than changing the formatter. =^..^=
