After i cleaned the laser unit after very bad copies when using the document platen glass an error code 52.00 appeared, followed by 51.21 all pointing to the laser unit. All I did was cleaning. How can i got this right
Laser Unit HP CM6040
Re: Laser Unit HP CM6040
If the printer was working before you touched it, always Back track; Did you clean the mirror inside?
Go back to everything you touched; you may have dislodged something a connector or left a smudge on a mirror or the motor;
You really should get a manual if you don't have one already; www.JustManuals.com
Perform the laser scanner component tests in the Troubleshooting menu.IzzyComment
