HP 5550 Transfer Kit
  • Absurd
    Just a brick in the wall
    • Oct 2007
    • 118
    Just wondering how hard it was to replace this unit. Im figuring its not to hard but this is for a non customer on a off brand printer to me so I would like to know a little something about what im doing before I show up.
    Southern Duplicating of Mississippi
    PSN: DrAbsurd (if you know you know)
    "If you love wealth more than liberty, the tranquility of servitude better than the animating contest of freedom, depart from us in peace. We ask not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains rest lightly upon you and may posterity forget that you were our countrymen." [Samuel Adams]
  • prntrfxr
    • 1622
    its very similar to 4600. lift up top cover, open front door, and pull down on green handles of the transfer belt. Then you will see 2 release levers on either side of the transfer belt. Just slide them back while pulling the belt toward you. Reverse process to install.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
      • 23006
      My customers do change these themselves. A user should have no trouble.
      • jcirafic
        • 11
        I agree with the comments above. This is an easy one, just find the release latches on either side and the hardest part is done.
        • jtymabel
          • Aug 2008
          • 164
          anything in a hp printer with light blue is customer replaceable
          • LaserSharp
            • Sep 2007
            • 94
            Its a very easy replacement, but if the machine is calling for it it's probably a good time for an overall cleaning and check of rollers ect.
            • Debrenlind
              HP Transfer Kit C9734B
              This is EXTREMELY EASY to remove and install another one. However, there's been a nationwide backorder of this product from HP since August. So if anyone knows of someone who has this in stock, I'd love to hear where.
              On this product, you just pull up on the tabs at the bottom where it connects to the printer. And then pull it off. That's all there is to it! You can install another by reverse it. It's just that easy!!
              • BrickPilot
                • Sep 2008
                • 41
                Maybe HP should have made their Photosmart range and other inkjets entirely out of light blue plastic then??
                • KEVIN900
                  Copier Ninja
                  • Oct 2009
                  • 200
                  Try Depot America for transfer kit
                  Kevin900
