HP color laser jet 4650.
  • MR Bill
    • 532
    Have a HP-4650 that is giving me a C.Q. problem. When you print out a config page the area where it is suppose to be grey is jet black. Example. The grey bar at top of page that say configure page is not grey it is very black. You can read configure page because it is white letters inside the black bar. Down the page you have smaller grey bars with , printer information , then Event log, Installed personalities and options, Calibration information, color density, etc. , well sense the greys are now black you can't read those words . The words on those grey bars are in black wording and with the grey bar now pitch black it's impossible to read it. Why is this printer making the greys BLACK? OEM carts, swaped them out. I'm at a lost. It was working ok and I added more memory and then this problem started. It comes and goes but is there most of the time.Connection?? I hope you understand what I'm talking about?Thanks.
  • ameritech
    • 96
    Re: HP color laser jet 4650.
    I work on alot of these and never had that problem. I would try swapping laser units, see if it makes a differences.
      • 23010
      Can you post a sample? =^..^=
      • JustManuals
        • Jan 2006
        • 9838
        Mr Bill - Do you need the manual? Send me an email.
        Paul
        • theengel
          • Nov 2011
          • 1784
          Maybe try running a calibration. If there's absolutely no change, do nvram dump and do the calibration again. On some of those color machines, I remember, the calibration stops having effect until you dump the ram. If it still doesn't help, I would change the transfer unit. A bad transfer unit will screw with the calibration.
          • MR Bill
            • 532
            Thanks for the replys.
            • Iowatech
              Not a service manager
              • 3930
              This is probably stupid, but it kind of sounds like a failing in the black developer, maybe bias or the control of such. So you might investigate the high voltage area of the machine, or maybe check to see that the controller is OK and properly seated?
              (Well, at least if all I did was add memory to a machine and has something like this happened, I'd check the controller first.)
              • KJEpps
                • Jun 2012
                • 63
                I would also suggest updating the firmware.
