hp lj 2300
  • tcypy1961
    • 773
    hp lj 2300
    customer was purchasing their cartridges themselves not sure if oem or compatible and has to periodically pull cartridge out and shake due to a light streak from lead edge to trail in same area. the cartridge(compatible) I sold them is now doing the same thing. Just defective cartridges. If a oem cartridge is installed and the same reults occur where do I look next???
    Thanks!!!
  • Wild Bill
    • Jul 2005
    • 774
    Re: hp lj 2300
    Scanner
    Izzy
      • 23009
      Re: hp lj 2300
      Originally posted by Wild Bill
      Scanner
      scanner?
      Are we talking about the same HP laserjet 2300?
      • tcypy1961
        • 773
        Re: hp lj 2300
        Scanner
        shaking the cartridge gets rid of the streak briefly; I don't believe there is a scanner on this printer; at least the streaks are mainly from printing.
        Thanks!!!
        • theengel
          • Nov 2011
          • 1784
          Re: hp lj 2300
          Are you sure a new cartridge is doing this? Customers love to insist they "just" replaced it--failing to tell you they've run 10000+ prints on it.
            • 23009
            Re: hp lj 2300
            I agree with theengel. I don't think that there's anything to fix here. When the cartridges get low, sometimes it runs out of toner at the front, or the back, or the middle. Just shake the cartridge a little if you want the last 25 prints from the dregs in the bottom of the cartridge. If you don't care so much, just change the cartridge. =^..^=
            • tcypy1961
              • 773
              Re: hp lj 2300
              It's doing it now is all I can say for certain; so maybe my cartridge???
              • theengel
                • Nov 2011
                • 1784
                Re: hp lj 2300
                My guess is that you just have an empty cartridge.
                • Wild Bill
                  • Jul 2005
                  • 774
                  Re: hp lj 2300
                  Scanner = Laser
                  Laser/scanner RM1-0313 2300
                  Izzy
                  • draph
                    • 132
                    Re: hp lj 2300
                    No, if it were a dirty laser, shaking the cartridge would have no effect.
                    • faxman28
                      • 435
                      Re: hp lj 2300
                      turn the cartridge over , open the flap that covers the drum, you should also be able to see the mag roller with the toner on it . Is there a corresponding line on the toner roller with your print ? also if you look at the top of cartridge were the scanner(hp likes to be different) writes to the drum there is a black charge roller on top of the drum, is there contamination or build up on the charge roller. if yes, it could be paper dust or if remanufactured faulty(inexpensive) parts. or the mag roller(toner roller) and charge roller aren't being replaced when remanufactured.
