my machine (hp3035) always had a paperjam just before the paper exits (halfway) the fuser assembly.. but no print can be seen as it passes through the toner drum . please help. thanks.
First things first, is the paper in the tray the same size as indicated? sounds like it thinks the paper should be legal and it's really letter. Check the backstop in the paper tray for proper alignment. Try running a page thru the bypass to prove machine is working properly. Hope it helps.
thom
thom
thnks for your response.. but what puzzled me is when I activate the sensors for the machine to think that there is actually toner cartridge inside the machine works normal.. but when i put the cartridge inside the problem persist it, the paper jammed right before exiting the fuser assembly and no toner powder is released by the cartridge.. but first ill try your advice.. thank you so much.
try to align the toner cart. ground... for the no image printing
and regarding of paper jam always : try to clean the fixing heating element put a silicon grease and replace the film sleeve and lower roller at the same time..
thanks..dreamz
Are you using a cheap Chinese toner cartridge refill? Quite often those cartridges are either poorly re-manufactured, or overfilled with toner. In either case, the toner cartridge is very difficult to turn, and can slow down or stop the drive motor.
First thing: install an OEM cartridge and see if it works. =^..^=
I would start by looking into the sensor right before the reg rollers. Theoretically, if it's not tripping, the paper shouldn't get past the reg rollers, but I can't tell from the timing charts if the sensor starts the print process only (meaning it gets the laser, dev., & transfer going) or if it starts that as well as keeping the paper moving. Having the cartridge in place might somehow change how the sensor flag is reacting with the paper.
That's the P3005 engine, isn't it. I don't have one in front of me, so I can't look. Maybe next week I'll see one and see if there's something obvious that could go wrong there.
In the manual, that's listed as the PS-901 top of page sensor. But in the timing chart, they've misprinted it looks like and call it the ps-801.
What is the jam code being thrown by the machine? That may give you clue as to what the machine thinks is wrong.
Elmtech is on to something here, it is important that we know what's on the display when the jam occurs. As you know, we can't physically see your machine and what it is doing.
Good catch, Elmtech!
