hp DJ 5000 error B0008 and other problems
  • landspeeder
    • Feb 2010
    • 355
    So I go on site a while back and find a printer that says some of the new or old printheads are not seated...if you take them out it detects there not there...put them in and it says to reseat them...its every other printhead not all of them...so I find the trailing cable is crunched up and a few traces are broken, at the carriage end and I feel that is the problem... also it throws a B0008 error which says that one of the cooling fans is not detected..they are plugged in.. so I change the trailing cable and it makes no difference...it goes to the B0008 error and no further but once it actually went to almost ready and said every 2nd printhead needs reseatting...So can a bad trailing cable have shorted anything?
    help!!! me!!!
    You never realize how cheap a professional is until after you let an amateur do it.... and
    if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    Re: hp DJ 5000 error B0008 and other problems
    Usually the reseat printhead error can be bad heads. How much is this plotter used? Printheads have expiration dates. They might still be usable, but if they expired, that is just cause to have customer replace them. Last plotter I had in shop had heads that expired 6 years ago.
    I don't think the cable is going to short out the board, as it is mostly moving data. No high voltage. You might try reseating the cable again.
    • landspeeder
      • Feb 2010
      • 355
      The plotter is in a colledge...so used a lot... but to have every other print head saying reseat...6 printheads...2,4, 6 saying to reseat...also what do you think about the b0008 ..manual says that if all fans are plugged in then change some pca board...can that board also affect the printheads....or is this two different issues?? What you think??
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        Usually plotters I get are military and basket cases when I get them. If this is a regularly used machine, and it woke up one morning with all of these errors and issues, then I would say it is most likely the board. However that is just a guess. If you want a better second opinion, HP has a public forum that any tech can use. Look for a senior poster named David Zuts. I got some questions answered when I first started working on plotters. He is still there. Get a price on the board, it may be cheap enough to go ahead and change. Keep in mind that a new plotter starts at over $4,000 and that makes anything on that one worth repair.
        • Kiran Otter
          • Dec 2013
          • 1115
          The trailing cable won't give you reseat messages, but it is critical that it's connected correctly and not damaged. A shorted trailing cable can damage the carriage and or main PCA. One printhead can affect others because they're in a sort of matrix. Always replace consumables first before replacing other hardware. If you can, take the printheads to another 5x00 and try them. Inspect the flex cables in the carriage that contact with the print heads. Ink and other dirt/debris can cause connection issues. Only clean them with water; I use Simple Green, but don't use alcohol, it will melt the plastic and deform the cable.
          On the fan, there's 2 and they plug into the power supply. They're almost always clogged with dust when I see them. Make sure the fans spin freely. If I remember correctly, one will come on, and then the 2nd one during initialization. If one isn't spinning, try swapping their connections; see if it's the fan or the board. If the fans have been clogged, the power supply may be shot from overheating.
          Kiran
          • theengel
            • Nov 2011
            • 1784
            Kiran,
            I appreciate all the answers you give us on these plotters. For those of us who are just getting into the plotter world, your experience (and willingness to share it) is valuable.
            • landspeeder
              • Feb 2010
              • 355
              Originally posted by theengel
              Kiran,
              Those are great answers!!! Thanks ..I did change the trailing cable because it was badly damaged and some traces looked broken....the trailing cable and the fans plug into the same board...so errors from both seem to point to the board...the service manual says for the b0008 error if the fan is ok and plugged in then change the board....it looks possible that since the board is common to both its bad
              • Kiran Otter
                • Dec 2013
                • 1115
                A B0008 means a power supply fan is not detected; the power supply fans plug into the power supply, not the main PCA.
                A B0007 means the vacuum fan is the problem, B0009 is the aerosol fan; both of these do connect to the main PCA.
                Kiran
                • Kiran Otter
                  • Dec 2013
                  • 1115
                  Kiran,
                  Thank you for the thanks! I know I don't know everything, and I've made my share of mistakes, but I like to try to help when I can.
                  Kiran
                  • landspeeder
                    • Feb 2010
                    • 355
                    So if the cooling fan for the power supply ia alright....then why does the service manual say to replace the main PCA...?
                    Kiran
                    • Kiran Otter
                      • Dec 2013
                      • 1115
                      Because it's a poorly written part of the service manual.
                      Are both fans at the power supply coming on? If they are, and you're getting a B0008, then either a fan's tach is bad, or the power supply is bad.
                      B0008 shouldn't have anything to do with the other fans or the main PCA.
                      Kiran
                      • landspeeder
                        • Feb 2010
                        • 355
                        Kiran
                        So I went on site today and found one of the fans in the power supply to be seized..put some oil on the bushing and away it went..no more b0008 thankyou!!!!!! So I am going to change that one as its a bit noisy. But back to the printheads wanting to be reseated...they are the odd ones 1, 3, and 5 even...2, 4, and 6 are ok....its got a new trailing cable soooo would you think the board in the carriage is bad...???
                        • Kiran Otter
                          • Dec 2013
                          • 1115
                          I would replace both fans. They come as a pair from HP for $82, or you can try to find an equivalent. There's a pair on ebay at the moment for $35.
                          I would replace the 3 printheads first. What's the date on them? You could try just replacing 1 of the 3 bad heads, see if it accepts it. If it does, get the other two. Check ebay; you can often find expired heads for a lot less than new ones. Make sure you get the proper type, dye or UV.
                          Does it accept 1 3 or 5 with the other printheads removed?
                          If new print heads doesn't resolve it, then I would consider replacing the carriage assembly. You won't find one at HP since the product is EOL. There is one on ebay for $725. (There's one from England for $256.) Make sure you get one from a 5000. p/n C6090-60029 The PCA in the carriage was never an individual part, unfortunately.
                          You might want to discuss if it makes sense to continue to repair it with the owner. Considering you can buy a whole 5000 for around $500-800, it sometimes doesn't pay to spend $700+ on a carriage and labor.
                          Kiran
                          • fixthecopier
                            ALIEN OVERLORD
                            • 4713
                            Any time I have had that, changing the heads is what it took.
                            • landspeeder
                              • Feb 2010
                              • 355
                              Kiran
                              They say they tried with new printheads with no luck...gave same error...now to get a carriage...its a school by the way so they are not allowed to buy a printer but can spend more than one would cost on repairs... also is the part# , P/N: C6090-60090 alright?
                              Thanks again....
