4700 60.02 code, need second opinion.
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    After they moved the printer to a new building they got the code. I found it sitting on a cheap table in the hall and set it on teh solid floor. I happened to have a 4700 I had picked up from another customer, so I swapped the tray and when that didn't work I swapped the lift motor knowing that the one I was taking off another customers machine was fairly new, I had replaced it a few months ago. That also didn't work. When the tray try's to lift, the knocking noise begins and lifting up on the tray or shimming under ir with about 10 or 12 sheets of paper folded in half makes it stop. At this point all I can think to try is to strengthen the spring pulling the motor to the tray. Any thoughts?
    • 23010
    Re: 4700 60.02 code, need second opinion.
    Maybe it's nothing, but on a LJ4350 I came across a tray that would not lift. It did not give a lift error, but I don't think a 4350 can give a lift error. About every other time, the tray would lift properly. The other times it never attempted to lift.
    While I was trying to diagnose the issue, this machine shut down completely by itself. If I left it off for 45 minutes we could start the whole thing again.
    My LJ4350 was losing it's 24vdc, because of a power supply failure. The only symptom was tray #2 not lifting. =^..^=
    • subaro
      • Oct 2010
      • 1274
      remove tray2 and power up. go to diagnostic mode and run feed test from tray 1 or just do a copy to pull from tray1. make sure tray1 paper size is set correctly.
      I don't remember if tray2 must be install before the machine can print, but check anyway. if it prints from tray1, then you can eliminate quite a few things and concentrate on the tray2 area.
      what i suspect, is tray 2 motor assy lift gear is not making full engagement with the tray lift gear and it is skipping tooths when trying to lift. maybe something was bent in the move.
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        You may be thinking of another machine. On a 4700, tray 1 uses tray 2. Machine will not work without the tray installed. I think I will just double up on the springs and see what happens.
        • subaro
          • Oct 2010
          • 1274
          I just had a look at the service manual and you are right. well, its been a while since i worked on those, so i was not quite sure how the configuration was.i was thinking of the mfp CLJ4730.. . But i still think if the machine was working before he move, then either the rails on the machine is broken or something is preventing the tray from sitting properly and therefore the both gears not engaging properly
          let us know the results then, we will learn from this fix.
          • fixthecopier
            ALIEN OVERLORD
            • 4713
            Well, putting two springs on it didn't work. Also, it being Monday, I wound up snapping one of the springs up into the printer and having to remove covers to retrieve it. The only other thing I can think of would be to change the piece you have to remove to change the the motor.
            • fixthecopier
              ALIEN OVERLORD
              • 4713
              Changing that piece didn't help, but while msing with it, I found that if I immediately open tray 1 when I shut tray 2, tray 1 seems to lift it a little and it works fine. It makes sence that they could have damaged tray 1 while moving. Guess I am swapping a tray 1 tomorrow.
              • Wild Bill
                • Jul 2005
                • 774
                Did you fix this?
                I have had this issue. the plates under the where the paper tray goes get bent. I reform them downward and bingo. hope this helps
                Izzy
                • fixthecopier
                  ALIEN OVERLORD
                  • 4713
                  Actually I got a little closer, or confused myself more. Swapped out the tray 1, and lower front door and it went from lifting only if you lifted or shimmed the tray to lifting if you shut the tray by pushing firmly on the right side of it.
                  • 20 year tech
                    • May 2014
                    • 577
                    Try removing the back cover and look to see if the rear cross bar of the frame is not bent in. If it is bent it keeps the tray from fully closing. good luck
                    • fixthecopier
                      ALIEN OVERLORD
                      • 4713
                      Was looking at it through the tray opening, but I have new glasses and everything looks bent.
                      • fixthecopier
                        ALIEN OVERLORD
                        • 4713
                        Well I went back and took a second look. Removed the tray and checked the cross bar in the rear. Put a straight edge on i, top and bottom, seemed straight. With no other ideas to try, I removed the covers and looked at it again and sure enough it was slightly bent in, to the front just enough to hold the tray out a hair. Hammered it back and works great. Thanks for the tip, I commented in your rep, thanks again.
                        I forgot my number one rule when working on base which is to remember who I am working for. The printer was most likely kicked. These guys could mess up a block of steel with a rubber hammer.
                        • MBT
                          • Aug 2010
                          • 51
                          One thing I've ran into on the 4700's is if the table is too small, the printer won't sit properly and apply pressure to the tray, preventing proper lift.
                          Is the table bigger than the printer or just a little too small? If the table is bigger than the printer and all feet are on the table, is the table warped?
                          Maybe try testing it on the floor?
                          • fixthecopier
                            ALIEN OVERLORD
                            • 4713
                            Thanks for the reply, but you didn't read my last post. It was fixed 2 weeks ago.
                            • MBT
                              • Aug 2010
                              • 51
                              This is what I get for reading in a hurry. My apologies and I'm glad you were able to fix it.
