Formatter board!
  • Abimotek
    • Feb 2015
    • 59
    [CQ] Formatter board!
    Complain Fomatter board!Pls help on below installation as result pop up,i got below, is any laserjet printer with name P1015?1, Usb composite device > ready to use2, usb printing support > ready to use 3, Hp EWS > no driver found4, Hewlett packed hp laserjet P1015 > no driver foundor any means to drive?Thanks
  • Wild Bill
    • Jul 2005
    • 774
    Re: Formatter board!
    communication error............................................. .................................................. ...................
    Izzy
    • Iowatech
      Not a service manager
      • 3930
      For what it is worth, it sounds like you might need to reinstall the software that came with the printer.
      • subaro
        • Oct 2010
        • 1274
        Mr. Abimotek.. The forum is here to help one another. But if your question is not understood, your help will be limited. so can i make a suggestion.
        place your description in short sentences and point form. example
        1. I need help with the installation of hp model xxxx
        2.
        3.
        Ok, so now try to post your question again to explain what you want done or what help you need
        wild bill will help you....he has lots of experience.
