Can I use the same film used in the P4014 fuser unit in the LJ4250 Fuser unit?
HP Fuser Film Sleeve
Tags: None
Re: HP Fuser Film Sleeve
By the way, a few weeks ago you posted about a dell printing black only. i replied to you and suggested some info. you replied once and never posted what the solution was. did you solve the problem. This is how others will learn, when you post your solution. i wrote much lines and gave info to you that you should have the time to reply.
so now you need hepl with hp or suggestions. Remember the forum is to help one another, and you have to contribute too.
As to your question on the hp fuser. I don't think anyone out there have tried that really. But , get a measuing device, check the length and circumference and if they match exactly, then no reason it should not work. And worst case if it does not, just replace the fuser.THE ONLY THING FOR EVIL TO TRIUMPH IS FOR GOOD MEN TO DO NOTHING..........edmund burke -
Sorry to hijack this thread guys but can anyone please tell a KonicaMinolta guy what grease to use for the HP fuser films?
Thanks!
Hans“ Sent from my Intel 80286 using MS-DOS 2.0“
https://www.copytechnet.com/images/smilies/biggrin.pngComment
Wont give the copy count as per OEM but will work as a good fill in for a short periodComment
its of course, its work .. also many fuser film is universal, too
_________________________________
copier, printer spare partsComment
correct.. its interchangably, many film sleeve film is interchangably , too..
spare parts for copier, printerComment
