T520 wont boot
  • sharpie
    • Feb 2011
    • 180
    T520 wont boot
    I have a T520 that when turned on it immediately [after a few seconds] displays 3723150 and does nothing else. Is this the HDD and does anyone know if this is replaceable off the shelf?
  • Kiran Otter
    • Dec 2013
    • 1107
    Re: T520 wont boot
    That's an odd error code/message. Is that all it displays?
    The error should be in the form of XX.YY:ZZ, like 01.1:19
    When power is applied, does it beep at all after about 30 seconds? 3 beeps means a bad front panel. One long beep means a possible bad main PCA. You can check for a flashing green LED in the bottom left behind the ink cartridge cover.
    See if you can get/post what the display shows.
    Kiran
    • Kiran Otter
      • Dec 2013
      • 1107
      Re: T520 wont boot
      Oh and there is no hard drive in this printer.
      • sharpie
        • Feb 2011
        • 180
        Re: T520 wont boot
        Yes, on power up there is the hp logo for about 30 seconds the a beep and the display shows B3723150 and the unit is inoperable from there.
        • theengel
          • Nov 2011
          • 1784
          Re: T520 wont boot
          You might try booting into diagnostic mode and going through each of the service tests.
          • fixthecopier
            ALIEN OVERLORD
            • 4713
            Re: T520 wont boot
            Wow, I googled that as an hp error and got 6 hits. 5 were not related, and one was this thread.
            • Kiran Otter
              • Dec 2013
              • 1107
              Re: T520 wont boot
              I asked my friend at HP; that error doesn't even come up in their system. So my vote would be for a bad PCA, especially if you're getting 1 beep (should be 1 long beep.)
              Kiran
