hp 4250 skews from both trays
  • dhg
    • May 2011
    • 26
    skewing from both trays 2 and 3. i have eliminated toner cartridge, actual trays, paper types, cleaned vertical guides reg rollers and checked for build up or foreign objects. 450k ideas ?
    • 23002
    Re: hp 4250 skews from both trays
    Is it skewing before or after imaging? That is to say, Is the image skewed on the paper, or is the image straight on the paper? =^..^=
    • dhg
      • May 2011
      • 26
      It is on printed image, so seems like registration area or prior, vertical
      • benalvarez
        • Feb 2015
        • 27
        does it skew when it is printed from the pc, copied from the platen glass, copied from the adf all the same way, or have you not explored those variations? Does that model have a usb plug? Maybe try to import an image from the usb stick and see if it skews that way too. It's real hard to understand every problem without being in front of the mfp. It could be something as simple as a sticker stuck in the paper path that you can't see.
          • 23002
          Well since an HP laserjet 4250 is just a printer, it could only affect printed images. And since it does not have a scanner or document feeder, it does not affect those operations. =^..^=
          • theengel
            • Nov 2011
            • 1784
            I would try replacing the reg assembly. But also check to see that all those plates and springs around the reg assembly are as they should. Every now and then I've had customers try to take them apart to find a jam and not get them back together properly.
            • benalvarez
              • Feb 2015
              • 27
              Okay does it skew from internal prints like a configuration page, or site map, or only prints from a pc? Are the fences in the tray static or do they move around, is there slop in the trays?
              • dhg
                • May 2011
                • 26
                it does it from any type of print,not every time but every 2 to 4 copies, the trays guides are tight...
                  • 23002
                  The worst skew that I've seen was caused by labels wrapping onto the registration roller at one end of the roller. The labels acted like a spacer, so the reg roller didn't have any pressure at one end.
                  My recommendation is to take apart the reg assembly and clean all the rollers. Also check that the pressure springs are all there. =^..^=
                  • Wild Bill
                    • Jul 2005
                    • 774
                    Its not an MFP...
                    I Agree with Black Cat and theengel
                    Inspect registration rollers... you can take all the screws out and at least clean the rollers or remove stuff that's in there, but there's a grounding screw and you cant get to it until you remove main drive assembly.
                    ***Also, I would check the little piece of foam that quiets the registration flapper; Just Like the solenoids the foam gets F'D up and creates glue so the flapper will get stuck up and wont align paper. See Pic...
                    http://www.copytechnet.com/forums/at...&thumb=1&stc=1
                    Next, change the Registration assembly which is kind of a big job, Good Luck
                    Izzy
                    • dhg
                      • May 2011
                      • 26
                      It's fixed , pre registration roller assy ....
                      thank you all for help !!!
                        • 23002
                        Congratulations on your success. Was there an obvious cause? =^..^=
                        • dhg
                          • May 2011
                          • 26
                          Yes i over looked the worn side of the pre reg roller on one side, lighting or angle was bad... Excuses excuses !!
                          It was damn obvious after i removed, i'm a dumb fuu...
                          i' m more of a copier guy.... I had double vision, i see dead people...the excuses never end
                          thanks again ! !
                          dave
