Hp color laserjet 4650 storage issue
  • shrum1340
    • Jun 2008
    • 44
    I have a cust with a HP color laserjet 4650 that is having a issue with storage. They will send over a 3 page doc and want 4 sets printed. The printer will print 1 set and then print out a " job storage status page"
    error- unable to store job at printer
    Reason- insufficient disk space for this job
    Solution- delete some files from the disk before resending this job
    i have done a nvram reset. Didn't change. I"m thinking memory dim, memory card, hdd, maybe formatter?
    firmware is at V.28.06.FF
    Anyone one had this problem before?
    • 23002
    Re: Hp color laserjet 4650 storage issue
    Perhaps a driver setting will help you.
    There is usually a checkbox for "Print after entire job is spooled." or "Print job as each page is spooled." Use the second choice. =^..^=
    • Iowatech
      Not a service manager
      • 3930
      I don't see any firmware updates for that machine, so the firmware that's on the machine now is going to have to do.
      Incidentally, I get firmware updates for HP here. If you are not in the United States you may have to look elsewhere on HP's website, though.
      Building on blackcat4866's recommendation, you might try a different driver.
      What are they trying to print when the machine has the error?
      • shrum1340
        • Jun 2008
        • 44
        It's a bank and they are printing stuff with text an some pictures. I have also had them print just text and still get the memory issue. I will have them try the spooling after each page. Another issue they had but is fix now was it would keep printing the same page until you stopped it. Then it would keep printing the next page until you stopped it. Copies in the printer were changed to 32000 somehow . So once I changed it to 1 it worked.
        • fixthecopier
          ALIEN OVERLORD
          • 4713
          The setting changed to 32.000 was caused by someone playing with the buttons who changed it, didn't know it, didn't know how to change it back and will not admit to anything. I have had that call many times on different equipment.
          • Hewlett Slacker
            • Apr 2015
            • 42
            disable the mopier function in device setting of the
            driver
