What would cause this HP LaserJet 4250n to overfeed? What I mean by this is that I only want to make one copy, but the machine pulls two sheets through, and the first sheet stops as a quarter (1/4) of the lead-edge is exiting. This problem is only with the second paper cassette. (The machine has two paper feed drawers and a bypass tray.) Thank you for any help given.
HP LaserJet 4250n
Re: HP LaserJet 4250n
Definitely a sticky paper pickup solenoid. Replace the solenoid unless you know the trick into replacing the sticky foam.Comment
I'll usually chemically clean away the old foam and any remaining two sided tape and adhesive. With a hole punch I'll punch a nice 1/4" disk of inner tube, or scrap rubber transfer belt, then glue it in place with cyanoacetate. The adhesive will never ooze through the rubber. It won't ever come off. And it won't ever make noise.
When I first discovered this fix I would just scrape away the foam and let it "clack". The drawback to this, is that the metal actuator will eventually magnetize if it contacts the metal solenoid core, and you'll get exactly the same effect as the sticky sound damping foam. Then you have to replace it. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Ditto that. The test is just to manually hold down the actuator for 10 seconds, then let go. If there is any delay in returning, you know that the foam is getting sticky.
When I first discovered this fix I would just scrape away the foam and let it "clack". The drawback to this, is that the metal actuator will eventually magnetize if it contacts the metal solenoid core, and you'll get exactly the same effect as the sticky sound damping foam. Then you have to replace it. =^..^="You can't trust your eyes, if your mind is out of focus" --Comment
I thought that sounded familiar. =^..^=If you'd like a serious answer to your request:
