Laserjet CP4025 ?
  • blackdog
    • Jun 2012
    • 211
    Laserjet CP4025 ?
    Is it possible to print a test pg (engine test) without Toner installed.
  • Iowatech
    Not a service manager
    • 3930
    Re: Laserjet CP4025 ?
    Why do you need to do that?
    My first guess would be no, but without knowing why you need to do that I could be full of crap. I don't like being full of crap, it's uncomfortable and I smell weird.
    So please tell us why you need to do that.
    Thanks.
      • 22999
      Since these cartridges are All-In-One units, you're not going to get any image on the paper without a toner cartridge, and most likely the machine will net even let you try. On some of the older HP's you can set electronic switches to allow interchanging of cartridges, but the full compliment of cartridges (4) must be installed before anything happens.
      • blackdog
        • Jun 2012
        • 211
        Thanks.
        t
        Why do I need to do That----------Because it's a future parts machine.
        My first guess would be no---------That would be my thought as well.
        How,s the kool aid
        • blackdog
          • Jun 2012
          • 211
          Thank You!
          • faxman28
            • 436
            go to diagnostics menu and go to disable cartridge check, should allow running with cartridge removed, and or swapping cartridge position. used to use it on older hp color printers to test for toner cart issues, laser or transfer belt. At least hp still has it in newer color printers.
            • blackdog
              • Jun 2012
              • 211
              YOU ARE THE MAN! Thanks
              • Wild Bill
                • Jul 2005
                • 774
                Blackdog that pic you have is tight!
                Izzy
                • blackdog
                  • Jun 2012
                  • 211
                  Great flip crib!
                  Open floor plan, modern plumbing, outhouse and well pump.
                  Kidding of course.
                  I really dig old historical stuff. Looks like a vintage 1940's petrol station from the layout though some have suggested an old
                  saloon where Hickok and the gang would tip a few. lol
                  Wish I had an old beat-up CJ in that pic though, would really do it justice.
                  Thanks for the comment.
