Re: Banding at HP T11xx
Probably should have used the syringe first. You want to get the air out of the lines first, so that it doesn't make its way to the heads. But you're probably fine. It's just that if there's air still in the lines, and you replace the head, and then the air gets to the head, you have to replace the head again.
