HP LASERJET CP 1215 colour problem
  • MWALA
    • Sep 2011
    • 30
    [CQ] HP LASERJET CP 1215 colour problem
    i have a cp 1215 which isnt producing correct colours. Is there any service adjustments to this. i changed catridges but still colour mismatches
  • theengel
    • Nov 2011
    • 1784
    Re: HP LASERJET CP 1215 colour problem
    Can you print out a diagnostics sheet and attach it?
    • Lasersupplies
      • Jul 2011
      • 221
      Are the toners originals or compatibiles? I have found with this particular model in the past that the compatible toner does not run well with this particular model. Also try and give the scanner mirrors a clean if possible.
      • rein
        • 2
        Try NVRAM Init and then few calibrations. Was chip-control disabled somewhen in the past?
