hp laserjet 4250
  • Orion2010
    • Jun 2015
    • 176
    hp laserjet 4250
    Hello all,
    i have hp 4250 and if i print make noise in fuser, i change the fuser but again make noise, ( on the left side )
    thanks
  • Itanic
    • Dec 2014
    • 59
    Re: hp laserjet 4250
    The part that you need to fix this is called a "Swing plate Assy".. it's a good 1 hour job for most tech's who are used to this machine. RM1-0043-020CN is the part number you need!
    • Has Been
      • Nov 2012
      • 48
      Originally posted by Orion2010
      Hello all,
      thanks
      You need to replace the SWING PLATE ASSEMBLY..check www.hp.com or partsnow.com for the procedure.
        • 23009
        75 minutes IMHO ... once you've practiced a few times. =^..^=
        • Lasersupplies
          • Jul 2011
          • 221
          Like all the others said, this is defintiely your swing plate assembly. Can be tricky enough to get out and in. You will see a lot of excess below the assembly where the teeth have been wore down.
          • Wild Bill
            • Jul 2005
            • 774
            Replacing the Swing Plate Assembly
            Izzy
