HP 4350 lines across pages
  • psteelers
    • Feb 2015
    • 38
    [Misc] HP 4350 lines across pages
    Hi all. I've got a HP 4350 that prints horizontal lines across pages down entire page. Lines are 1/4" apart with random splotches on the lines down entire page. The actual printed image is very faint in the background. If you print an Engine test, the lines that normally run vertical, only print at top of page, then fade quickly. The horizontal lines are still there on Engine test. Same spacing and splotches. Tried different toner cartridge with no change. Tried different transfer roller, no change. I thought the toner ground spring was bent out of position as they had said removing toner was difficult at best. Found toner tension spring on left side to be very loose. Tried re-bending it and also total tear down to try to repair it. No change.
    Question is: It could be the LVPS/HVPS unit or the DC Controller (which I think is aka Engine board), I just don't know which or if there is something else like a broken spring contact I can't see.
    Any ideas?
  • walterman
    • 196
    Re: HP 4350 lines across pages
    Have you checked the laser unit shutter and made sure it is fully opening? Sometimes the shutter assembly breaks and the shutter does not fully open and it could cause this issue. I would think, that if the printer was not getting the proper voltage, it would trigger a possible code, 41.x, etc.
    • Printerdude
      • May 2015
      • 119
      Are the toner cartridges remanufactured or new OEM?
      • 1stcavvet
        • Apr 2015
        • 231
        I say there's a grounding problem with the cartridge, block the ground with a piece of tape and see if it doesn't go completely black, the wierd part is the pattern, are the lines evenly spaced? that would mean something ticking something, gear moving somthing, some wiggle. check the wiring on the board on the right side. GOOD LUCK
        • psteelers
          • Feb 2015
          • 38
          First. Thanks all for replying. Here's a follow up. Tried new Transfer Roller, bending contact spring under block where it contacts the HVPS, Engine test with and without Formatter installed, a known good DC Controller, a known good Laser/Scanner (I even removed the shutter altogether, that's for you Walterman) and different toners, and unfortunately, yes they are aftermarkets Printerdude.
          Still get the same lines horizontally, but on some toners, the lines go away and are replaced with a blotches down pages. Looks like hundreds of small bubbles jumbled together. Any ideas? 2.JPG1.JPG
          • walterman
            • 196
            If I'm reading correctly on your, follow up, you mentioned the cartridges are aftermarket, have you tried an OEM toner cart.? Have you checked the wall voltage and ground?
            • psteelers
              • Feb 2015
              • 38
              This hospital doesn't use OEM's. I"ve never had this issue with them before and I did try a working one from another location. Wall voltage is good and a loaner printer is working fine in same spot. Tomorrow I may try to continuity test the contact springs. Thought of it too late for today.
              Thank you.
              • walterman
                • 196
                Wow, I'm stumped, the only other thing I could think of is swapping out the 110 power supply board (PN- RM1-1173). Let us know what you come up with.
                  • 23009
                  I've seen primary charge problems plenty of times and this looks like primary charge. IIRC the high voltage is on the power supply. That, and those dreaded aftermarket cartridges. Just for my peace of mind I would install an OEM, just this once. =^..^=
                  • Printerdude
                    • May 2015
                    • 119
                    Wow! Printed pages looks like a toner cartridge issue. Make sure the toner cartridge guide are intact and toner cartridge fully seated. You can try removing the power supply and clean the contacts on the power supply and springs. Try a OEM toner cartridge, I never trust a remanufactured toner cartridge before eliminating parts first. Could be the power supply needs replacing.
                    • wseyller
                      • Sep 2012
                      • 1129
                      The small bubbles you mention are definitely an issue with high voltage but the toner could cause that. Could easily be a bad batch of toners. Some remanufacturers have 1% defect rate and some have 30 to 50% defect rate.
                      Sent from my XT1254 using Tapatalk
                      • psteelers
                        • Feb 2015
                        • 38
                        You guys are great, however the problem still exists. I tried and OEM toner, continuity tested the spring contacts, cleaned said contacts, tried raising/lowering toner position with lid sensor tricked, and tested all toners in other machines. They worked good.
                        This may go down as a win for the machines. I'll let you know if I ever figure it out.
                        Thanks again for all the suggestions.
                        • Elmtech
                          • Nov 2013
                          • 155
                          Check the ground contact for the drum unit. I had a similar issue to the bubbled print years ago on an HP 400 and turns out i removed the ecu and forgot to attach the ground spring on the left for the drum ground back when i reassembled it.
                          • theengel
                            • Nov 2011
                            • 1784
                            I've seen developer units cause this exact problem in machines that don't use cartridges. I would look there, in the contacts between the mag roll & the machine. But I have a feeling it's in one of the power supplies. High or low... I think they both contribute to the voltages going into the unit. I think the LVPS provides the devoloper bias, but I'm not sure.
                            • Wild Bill
                              • Jul 2005
                              • 774
                              its the power suppy assembly
                              Izzy
