XM3150
  • deputydogg
    • Nov 2015
    • 172
    XM3150
    Re: XM3150
    Originally posted by deputydogg
    When you try to copy a document either off the glass or from the document feeder the only thing displayed is “scanning” and the only way to get rid of it is to turn off then on. The firmware is current. It will print internal reports but that’s it. They only use it as a stand alone copier.
    Bad flatbed ?
    Thanks,
    Dave
    Just to be clear:
    1. Can you print from a PC? (Try printing from your laptop)
    2. When you make a copy from the glass, does the mirror move and return to home position?
    • deputydogg
      • Nov 2015
      • 172
      Re: XM3150
      Just to be clear:
      Yes I can print the it. The scan lamp never comes on nor does it move.
        Re: XM3150
        It's odd that it doesn't throw up an error code and it just says "scanning" on the display. Sounds like a board problem.
        • tsbservice
          Field tech
          • 7963
          Re: XM3150
          Start with finding a manual and go from there unless someone here isn't having this problem.
            • 22997
            Re: XM3150
            Did you print the error log? Codes can be recorded that never show on the display. =^..^=
            • zenkinsw
              • May 2019
              • 5
              Re: XM3150
              Hi deputydogg,
              There is a Lexmark service bulletin in their support website, please refer to the Document ID:TE676
              basically try the following and see how you go:
              1. Backup all their settings first
              2. Perform NVRAM reset
              3. Go Configuration menu > Factory reset > Restore base
              4. Go Configuration menu again > Wipe all settings
              5. Go Configuration menu again > Format fax storage
              6. Go Configuration menu again > Disable LES applications
              If there is HDD install on the device, you might want to Erase all information on disk option in Config menu...again..
              hope all these help.
              Document ID:TE676
              • trc
                • Jan 2007
                • 95
                Re: XM3150
                Sometimes it could be an adf sensor, check them!!!
