X654 firmware error 900.24 at power on
  • rthonpm
    • Aug 2007
    • 2853
    I've got a customer that's asked me to look at a tabletop Lexmark X654xe. When powering up, it gives a firmware error of 900.24. The manual isn't that detailed beyond the code being a controller error. Hoping someone here has a better idea of what the issue may be, and if there's a way to bypass the error to at least try reloading the firmware.
    I'm mainly a Ricoh and connectivity guy, but I've serviced several other Lexmark models: this is the first time I've seen a full-on POST error on one.
  • dalewb74
    • Feb 2018
    • 1143
    Re: X654 firmware error 900.24 at power on
    remove the network connection and see if you get that error after reboot.
    • Blizzoo
      • Aug 2013
      • 608
      Yes, clear any corrupted print jobs in the queue if any and do as above
