Hello everyone,
I need some advice. I have a Lexmark CS727 for repair. There is a problem with reading the magenta toner. I replaced the TMC card and still have the same problem. The error I get is 43.42z to replace the magenta toner. I replaced the drum unit kit as well as the developer set because I thought that something was stopping the toner from starting. I also tried with the new firmware but the problem is the same. Does anyone know if there is anything else I should check before giving up on the repair?
