XM 7155
  • chargeroller
    • Oct 2024
    • 21
    XM 7155
    Machine is having 241.08 jams, not constant. Machine was making noise before it started jamming. The noise is an intermittent rattling noise from the left side.
  • dalewb74
    • Feb 2018
    • 1153
    care to share what you have tried to do to fix the issue? firmware? replaced any parts?
    • LlessurElad
      • Apr 2024
      • 11
      Have not replaced anything, have not done firmware. We are not a Lexmark dealer. Please help!!
      • LlessurElad
        • Apr 2024
        • 11
        OK. So the noise wqs coming from a bad aftermarket toner cartridge, Any tips on solving 241.08 jams?
        • LlessurElad
          • Apr 2024
          • 11
          I'm also getting an indication to reinstall missing or unresponsive imaging unit (31.66). Will this cause jamming?
          • dalewb74
            • Feb 2018
            • 1153
            reach out to your local lexmark dealership and have them send a trained technician out to fix the issues.
            • Hoosierdaddy
              • Oct 2016
              • 181
              Well Dale I thought this site was to help people within the Office Equipment Community Fix things But maybe Not The Tech that posted this is in a tight spot and a Veteran Any helpful comments would be appreciated.
              • dalewb74
                • Feb 2018
                • 1153
                but the fact remains that a typical user is more likely to do more damage than good. then you pay more in the long run to get a certified tech to fix it.
                • dalewb74
                  • Feb 2018
                  • 1153
                  A misfeed occurred due to shingling. The misfed
                  media is flushed to the output bin.
                  Press Continue to print using the next available
                  media.
