Lexmark 920C- says replace all color developers
  • rdavisalan@gmail.com
    • May 2009
    • 40
    [Error Code] Lexmark 920C- says replace all color developers
    Lexmark 920C- says replace all color developers. Did that twice, cant get the message to disappear. I am able to print by hitting continue on the screen. I thought once you replaced the developers the message auto clears. Please help. Thanks in advance.
  • Jantje
    this message means that all color photo developers, this are the drums, not the toner cartridges. The message should disappear when you do that.
    succes.
    • Silvertoast
      • Feb 2010
      • 270
      i think u have to go into menu settings and reset the counters
        • May 2009
        • 40
        i tried that already, this is what Ive done: reseated several times, replaced toners, replace developers twice, cleaned contacts and did factory reset. even went into diagnostics and reset counters for other components, and firmware of course. Next thing I will try will be a main board. I guess.
          • May 2009
          • 40
          succes.
          the developers and drum come toegether as a unit.
          • JustManuals
            • Jan 2006
            • 9838
            Yes, keep replacing parts until you get it right.
              • May 2009
              • 40
              yes, keep talking trash until you get smacked.
                • May 2009
                • 40
                Sometimes you have no choice but to do that, like in this case because the manual doesn't give the technician enough information( must have gotten it from those crooks at manuals4you). Of course I can't expect somebody with no field experience to understand that.
                • mojorolla
                  The Wolf
                  • 2632
                  He is a douche bag, pay him no mind. Have you tried running auto color adjust in the configuration menu? Did you replace the supplies with the unit unplugged and then turn it back on?
                    • May 2009
                    • 40
                    No I haven't tried both. Thank you. I will give it a shot.
                    • JustManuals
                      • Jan 2006
                      • 9838
                      I am certified on Lexmark, HP and Xerox Phaser printers.
                      And you are an asshole. Your days are numbered here bud!
