T642 still gives error.
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    The machine had a 920 fuser error when you would turn it on, I changed the fuser and it cleared. Now they call back and say it is coding every once in a while. Any Ideas??
  • prntrfxr
    • 1627
    What is the sub code? There are like 4 pages in the service manual for sub codes for the 920 error. Some are fuser related and others have to do with LVPS and proper line voltage.
    • Silvertoast
      • Feb 2010
      • 270
      had a lil lex printer do that, it was the power supply.
      • fixthecopier
        ALIEN OVERLORD
        • 4714
        I beleive the sub code was 4
        • prntrfxr
          • 1627
          920 .04 Hot roll too cool when
          heating to desired
          temperature after slope
          change (standby control
          only). Fuser page count
          between 0 and 99,999.
          • Bad thermistor, circuit or cabling.
          • Fuser not receiving sufficient AC
          power.
          • Poor supply line voltage.
          • Low wattage or incorrect lamp.
          • Incorrect hot roll.
          Service Check:
          1. Fuser lamp
          Fuser lamp AC cable
          Observe the lamp through the left near side of the printer. It may be
          necessary to remove the redrive assembly to observe the lamp
          turning on and off. If the lamp does not come on do the following:
          • If not previously removed, remove the redrive assembly. See
          “Redrive assembly removal” on page 4-75.
          • Remove the fuser assembly. See “Fuser assembly removal” on
          page 4-27.
          • Make sure the correct type of lamp is installed (voltage and
          wattage).
          • Verify that the fuser to fuser lamp cable is installed correctly to the
          fuser top cover assembly. If incorrect, install correctly; if correct,
          go to step 2.
          2 AC line voltage CAUTION: When taking measurements for AC power, observe all
          safety precautions.
          Check the AC line voltage to make sure it is within operating
          specification. If incorrect, inform the customer; if correct, go to step 3.
          3 LVPS CAUTION: When taking measurements for AC power, observe all
          safety precautions.
          Unplug the AC line cord from the printer and pull the LVPS out far
          enough to access CN1 on the LVPS board (see “Low voltage power
          supply removal” on page 4-55). Disconnect the LVPS to fuser AC
          cable, plug in the line cord, turn the printer on and measure the
          voltage between CN1-1 and CN1-3 on the connector (see the
          connector locations at “Low voltage power supply” on page 5-10).
          If incorrect, replace the LVPS assembly (see “Low voltage power
          supply removal” on page 4-55); if correct, go to step 4.
          4 Fuser lamp
          Fuser top cover assembly
          Fuser connect cable (fuser
          to fuser lamp cable)
          Check continuity of the fuser to fuser AC cable, fuser top cover
          assembly, and fuser lamp by checking the continuity between the two
          pins on the fuser lamp AC cable connector:
          • If there is continuity, go to step 5.
          • If there is no continuity, check the continuity of the fuser to fuser
          lamp AC cable. If incorrect, replace the lamp, if incorrect, replace
          the fuser top cover assembly.
          Note: If the fuser lamp is replaced, allow the fuser assembly to cool
          or a 925.xx error may be displayed.
          5 LVPS
          LVPS to fuser AC cable
          safety precautions.
          Check the AC line voltage between the pins on the fuser end of the
          LPVS to fuser AC cable. If the voltage is correct, unplug the AC
          power cord from the LVPS cable. If the voltage is correct, unplug the
          AC power cord from the LVPS, pull the LVPS out far enough to be
          able to check the voltage between CN-1 and CN1-3 on the LVPS
          board. Plug in the power cord, turn the printer on and check the
          voltage. If correct, replace the LVPS to fuser AC cable; if incorrect,
          replace the LVPS assembly.
          Note: If the fuses in the LVPS are blown, the LVPS assembly must be
          replaced.
          6 Fuser top cover assembly
          (thermistor, thermistor
          cable)
          Fuser to system board DC
          cable
          Check to make sure that the thermistor is installed correctly to J5 on
          the fuser control card. If installed correctly check the cable for any
          signs of damage. If any problems are found, replace the fuser top
          cover assembly. If no problem is found, check the fuser to system
          board DC cable for correct installation at J1 on the fuser control card.
          If no problem is found, check the fuser to system board cable for
          correct installation at J10 on the system board.
          7 Error code 920.06
          displayed
          LVPS
          System board
          System board to LVPS
          cable
          Carefully check the installation of the LVPS to system board cable to
          J27 on the system board and to CN2 on the LVPS. If the cable is not
          seated or installed properly, reseat the cable and retry the printer. If
          the cable is installed correctly, replace the following FRUs in the order
          shown:
          • LVPS assembly. See “Low voltage power supply removal” on
          page 4-55.
          • System board assembly. See “System board and inner shield
          removal” on page 4-77.
          • LVPS to system board cable.
          8 Fuser assembly If no problem is found up to this point, then replace the following in
          the order shown:
          • Fuser assembly. See “Fuser assembly removal” on page 4-27.
          • LVPS. See “Low voltage power supply removal” on
          page 4-55.
