100.01 Error Code Fix
  • cscce
    • Jun 2014
    • 156
    Lexmark 100.01 Error Fix
    This applies to the Lexmark C782 and any model that uses the 40X0343 ITU.
    If you get a 100.01 error when installing a new ITU you can probably fix it by adjusting the tracking cam on the ITU.
    2. Loosen the locking screws 1/4 turn or so (just enough so the metal block moves when the cam is adjusted).Lexmark ITU Tracking Cam.jpg
    3. Now adjust the cam. If the belt is tracking too far to the REAR of the printer turn the cam COUNTER CLOCKWISE one or two ticks to move it toward the front.
      If the belt has been tracking too far FORWARD then turn the cam CLOCKWISE one or two ticks.
    4. Tighten the locking screws, reinstall the ITU and run the belt tracking utility. Run the tracking utility twice (it may fail the first time because the belt position is changing). If it fails the second time remove the ITU to see if further adjustment is needed.
    5. Follow the above steps until the belt tracks properly (i.e. it passes the tracking test).
    • 22996
    Re: 100.01 Error Code Fix
    This is good to know. Thanks cscce. =^..^=
