Epson Aculaser C1100 code E533
  • tsbservice
    Field tech
    • 7635
    Hi All,
    This one was in warehouse, almost new.
    Cannot initialize, cuz error E533. I had no knowledge/training for this brand, nor documentation.
    Google says something about temperature/humidity thermistor.
    Could someone shed some light, please?
  • Lance15
    • Jun 2015
    • 1069
    Re: Epson Aculaser C1100 code E533
    This may help. I can extract more pages from the manual if needed.
    C1100 - E533.pdf
    • tsbservice
      Field tech
      • 7635
      Thanks Lance15.
      Unfortunately I have no spare parts/printer to exchange and I'm in doubt that may purchase here parts.
      Three more questions:
      1. Where is located thermistor.
      2 Is there some code/codes in service menu to disable sensor, or to tweak his measurement accuracy.
      3. Do you have experience with these goes bad.
      TIA
      • Lance15
        • Jun 2015
        • 1069
        Dell used this model for their 3000/3010/3110 versions. This was also used by Xerox for their version (DocuPrint C525A)
        Here's how to replace that sensor:
        Sensor Hum & Temp.pdf
        You can get the sensor here:
        130K87800 - Xerox 550 Hum/Temp Sens, For use in the 550, 560 Item Inc.
        • tsbservice
          Field tech
          • 7635
          So, I went and found thermistor a bit disconnected. Now I have E511
          Google says it have to do with square patch on transfer belt and sensor, if I'm not mistaken.
          Patch is there and clear, sensor was cleaned, mashine run calibration but fail throwing E511 after a minute.
          I tried to move the belt a little back and forth without success.
          Any other ideas?
          • Lance15
            • Jun 2015
            • 1069
            Your chasing a REALLY dead horse. I'd call it..........
            Epson C1100revB E511.pdf
