Service Manual w/ Error Codes
  • kymomof
    • Jan 2017
    • 5
    Does anyone know where I can purchase a service manual for a Canon 6000 ImagePress that lists all of the error codes and steps to fix/clear them? We used to have a PDF with all of the codes for the machine, but unfortunately it wasn't backed up and the computer had to be reloaded with the software. Thanks!
  • teckat
    • 16083
    Re: Service Manual w/ Error Codes
    Error Codes ImagePress ----see link
    lucky day-------------https://www.dropbox.com/s/slkl280jb0...Codes.pdf?dl=0
    • kymomof
      • Jan 2017
      • 5
      Thank you!! We bought a manual online, but some of the codes were missing.This one has it on there.
      • Liebendeinsam
        • Jun 2015
        • 12
        Link down.
        • kymomof
          • Jan 2017
          • 5
          Would you know what sensor is causing error 20-0381-05? We haven't been able to figure it out. We would be happy to pay for phone support. Companies in our area no longer support our machine. Thank you!
          • teckat
            • 16083
            E020 (Error in ATR)
            u mean e020-0381 ?---in your case that is CYAN
            0x81
            Lower limit error in light intensity on drum base (reflecting light intensity from the drum surface)
            DISPLAY>DENS>P-B-P-Y/M/C/K(Measured value of drum base)<150
            COPIER > Display > DENS > P-B-P-Y/M/C/K is less than 150
            did u Clean the patch sensor ??
            Highly possible = Soil on the ATR sensor *1
            *1
            : Soil on the ATR sensor
            Field Remedy
            1) Clean the ATR sensor with alcohol.
            [Note]: Wipe the sensor in one direction more than 3 times. Do NOT wipe it back-and-forth.
            2) Replace the ATR sensor with a new one.
            In addition, for the purpose of preventing any future occurrence, follow the steps 2-1. or 2-2. below.
            2-1) Service mode(Level 2) > COPIER > Adjust > DENS > HLMT-PTY/M/C/K,
            - If the current value is 4, change it to 9.
            - If the current value is 9, change it to 10.
            [Note]: Density might decrease as a negative effect. Therefore, execute the above setting value change only if soil on the sensor occurred at less than 250K
            intervals of periodic cleaning maintenance for ATR sensor.
            2-2) Shorten the interval of cleaning maintenance.
            Low possible =
            Faulty pressure for developing assembly
            =Broken wire of ATR sensor
            =Damaged ATR sensor
            =Malfunction of ATR patch detection shutter
            x = is the indicator for color at issue
            = 1:Y 2:M 3:C 4:Bk
            see link--for all error codes on imagePress
            • kymomof
              • Jan 2017
              • 5
              **SORRY just saw your other post with explanation. Looking at it now.
              The ATR error E020-0x81-000 Lower limit error in light intensity on drum base (3=Cyan) (reflecting light intensity from the drum surface) DISPLAY>DENS>P-B-P-Y/M/C/K(Measured value of drum base)<150
              We're not sure if the drum needs to be replaced, developer assembly or a sensor?
              • teckat
                • 16083
                patch sensor on c6000 remove
                start by cleaning the sensor first
                drums usually last 700,000-800,000
                on these printers u need to follow it's maintenance schedule- especially filters and coronas
                Filters should be checked on every visit. Determining the type of environment will give you an idea of how often filters should be checked and clean. Certain locations like dusty rooms, large open warehouse spaces, textile locations , areas with large ac units or with big running equipment are susceptible to filters clogging up quickly. Ensure that the filters are clean, if not the copier will not perform to its optimum capabilities.
                Filters can be replaced using
                Filter Kit FO2-5928-000
                Canon imagePRESS C7000VP Filter Maintenance Kit - 1M-- F02-5928-000
                Canon imagePRESS C7000VP Fuser Rebuild Maintenance Kit - 750K --
                F02-5925-000
                Canon imagePRESS C7000VP Maintenance Kit - 1.5M--
                F02-5927-040
                Canon imagePRESS C7000VP Maintenance Kit - 200K
                Canon imagePRESS C7000VP Maintenance Kit - 300K
                Canon imagePRESS C7000VP Maintenance Kit - 750K
                Canon imagePRESS C7000VP Maintenance Kit - 900K
                • kymomof
                  • Jan 2017
                  • 5
                  Thank you!!! You really helped us out of a jam.
                  • teckat
                    • 16083
                    Welcome and good luck.
                    ๐Ÿบ
