Canon imagePROGRAF iPF765 service manual
  • 1stcavvet
    • Apr 2015
    • 231
    Anyone have access to a service manual for this machine, I need to know what this error code is(031300312e23) I guess it's supposed to be a cutter problem code. and I'd like to know how to go about getting in and out of it. THANKS
  • laitang
    • Nov 2012
    • 627
    Re: Canon imagePROGRAF iPF765 service manual
    View and Download Canon IPF760 series service manual online. A4- to A0-size. iPF760 series printer pdf manual download. Also for: Ipf750 series.
    • 1stcavvet
      • Apr 2015
      • 231
      I have to replace the cutter motor on this machine. To replace the whole cutter unit you are supposed to drain the ink before you start, I only have to install a new motor on the cutter unit, is it still necessary to drain the ink first??? Thanks
      • craigster
        • Apr 2016
        • 201
        I have both service and parts if you want them
        • 1stcavvet
          • Apr 2015
          • 231
          I already have a motor for the cutter on order thanks, do you know is it necessary to do an ink drain before I can replace the motor??? I know you need to drain the ink if your doing the whole cutter assembly but do you have to when only doing a motor???
            • 23009
            I wouldn't. You'd just be throwing away $200 worth of ink and maintenance cartridge. Maybe HP just wants you to buy more ink? Sounds stupid. =^..^=
