xerox d110 manuel
  • Apouthe Donald
    • Mar 2014
    • 82
    xerox d110 manuel
    hello i have a xerox d110 which displays 042-312.
    -I need your help and also need documentation.
    here are the different works to realize
    1-I replaced the AC ventilator
    2-I replaced the engine Drum
    3-I replaced fuser exhaust fan / fan transfer and fan intake fan.
    after all this the code 042-312 is still present. thank you and need your helpers
  • adriansto
    • 2388
    Re: xerox d110 manuel
    I have it in edoc and pdf format.
    My mail = stoadis@gmail.com
    • gpoffmachs
      techie
      • Feb 2005
      • 55
      BSD 9.13 (D95/D110/D125 Only), BSD 9.13A (D136 Only)
      [IMG]pws://file/xerox/edoc/95-110-125/icons/arrwup.gif[/IMG]Description
      [IMG]pws://file/xerox/edoc/95-110-125/icons/arrwup.gif[/IMG] Procedure
      [IMG]pws://file/xerox/edoc/95-110-125/icons/caution.gif[/IMG]CAUTIONThe Accessories have their own power cord. Whenever a procedure states to Power Off and then Power On, POPO, etc., powering Off and then powering On the IOT does NOT Power Off the Accessories. The Accessories will have to be Powered Off and then On separately from the IOT by unplugging the Accessory power cord.
      Check the following:
      Techie
      • Apouthe Donald
        • Mar 2014
        • 82
        Thank you very much for the help, the machine works well. I would like to know:
        1-you are in which country?
        2-are you selling xerox equipment
        here is my email: fredonaldy@gmail.com and my whatssap number 0022558549509
        • adriansto
          • 2388
          Check fuse F11 on IOT pwb
          • VINCENT23OMAN
            • May 2021
            • 14
            [IMG]pws://file/xerox/edoc/95-110-125/icons/arrwup.gif[/IMG]Description[IMG]pws://file/xerox/edoc/95-110-125/icons/arrwup.gif[/IMG] Procedure
            hello and good day, im having the same issue in my Xerox D125 error code 042-312, I check the back of the machine and all the harness but there is no tagging or marking on the harness. I couldnt locate where is the wire harness BSD9.13
            • adriansto
              • 2388
              BSD 9.13 is the schematics I posted in #11 on your open thread. On this schematics you see the connectors numbers and wires. If you cant manage to use this then place a call to xerox tech.
              • VINCENT23OMAN
                • May 2021
                • 14
                found the harness and tried to disconnect it from the board and recon and tried to on the machine. Still error is there. Maybe the board is defective
