Kip 7170 service entry
  • kenoking
    • Jul 2022
    • 22
    Looking for service entry to check fuser speed for voiding on long prints. Had a manual, then had a flood in business. Manual go bye bye.
    Any help would be appreciated. I found 7170k online but not the same animal I do not believe.
    • 22997
    Re: Kip 7170 service entry
    Does it look like this?:
    I caused this issue after changing a drum. The cast aluminum drum retainers/brackets were incorrectly seated, causing the paper to ripple while passing below the drum. I got a bulletin from Kip that was supposed to resolve the issue adjusting motor speeds. I spent ~ 2 days on this problem. Eventually our KM rep came out and found the retainer issue.
    I can include the bulletin, but for me, it was the wrong path to a solution.
    You can remove the side covers, and watch the paper passage ... seeing the ripple begin. Here is my database entry:
    Voids areas of a seemingly random shape, on 18" & 24" wide paper, and 17.5" from trailing edge, seen on Arch D sized images and larger. Missing pieces of image appear 9.88" further down the page. Replaced pressure roller (Z164400850), bearings ([2]9000780174), nail set lower-set of 7 (Z160980130). Adjusted fuser motor speed in BUD 702 (40 > 0) for some improvement. Transfer issue? Re-position drum mounts, so that the bearings seat properly, and the mount fits tight to the frame.
    I pulled out a lot of my remaining hear on this issue.
