Toshiba ES-233 parts manual
  • Vincent128
    • Sep 2015
    • 345
    Yes, I know this machine is old as dirt and likely not able to find any parts but I have one of THOSE customers that insist ...looking to just try and cross reference some things and also see if any of the old crap I have lying around is to this model as I simply don't know.
    I have the SM just not the Parts Manual and it's been delisted from Toshibas sites.
    They could use the hi-low clutches in the vert transport and for sure a drum blade as it's gone hard, but finding a DEV-PM kit in my pile of obsolete would be swell if I knew the part number..oh and the drum too.
    • 22946
    Re: Toshiba ES-233 parts manual
    Parts manuals are on a proprietary application that required a license. Your best bet is to have one of us look up numbers for you, or go to Precision Roller. And yes, you're not going to find much in the way of parts. Most of them got traded in 7 or 8 years ago when they needed a developing unit and/or developer, and it wasn't available back then. =^..^=
    • Vincent128
      • Sep 2015
      • 345
      Yes I know ..I am a fully trained Toshiba dealer...and a contributor with some reputation.
      My manuals archive simply doesn't contain the parts manual so I can cross reference all the old ass parts and parts machines I have in the bone yard...but if you really want to come do that for me with your copy of the manual, I would be okay with it. ;p
      • Thayer
        • Dec 2017
        • 107
        6LA27845000 blade. used still in B/W model slow speed. 41303611000 OD1600,drum used from es 16 to e233 models.
        Clutches i believe are in same series, maybe used in couple color boxes 2330c/2500c
        hope this helps
        • Vincent128
          • Sep 2015
          • 345
          hope this helps
          Do you have the pm kits numbers and what flavor of developer it takes? I don't know the DP#### info, that's before my time with Toshiba stuff
          • Thayer
            • Dec 2017
            • 107
            6LA85750100 dev kit 2340, D-2320 is the developer used with od-1600 drum. The pm kit usually comes with the developer
