Don't have the manual but have a few of the codes. Diag Codes 1-2 Line Voltage Check 2-60 Copy Limit Program 2-61 Configuration Program 3-0 Exit Diagnostic Mode Program 3-5 Serial Communications Program 3-6 Serial Communications Program 3-9 Serial Communications Program 3-60 Main PWB Initialization 5-16 ADF Lead Edge Registration. 5-51 Single Sheet Feeder/ADF Prefeed Timing Test 5-52 Single Sheet Feeder/ADF Registration Timing Test 5-53 Single Sheet Feeder/ADF Prefeed Timing Test 6-0 Scan Initialization 6-1 Scan Servo Program 6-4 Scan Reference Frequency Line Test. Caution: Disconnect P126 from the Scan Drive Motor PWB before using. 6-5 Scan Rate Feedback Line Test. Caution: Disconnect P126 from the Scan Drive Motor PWB before using. 6-6 Scan Direction Line Test 6-7 Scan Enable Line Test. Caution: Disconnect P126 from the Scan Drive Motor PWB before using. 6-8 Scan Servo Compensator Line Test 6-9 Exposure Sensor Program 6-10 Lens Stepper/Lens Home Sensor Program 6-11 Scan Encoder Output Test 6-55 BookMark 21 & with TAG P-019 : Scan Speed Program. 6-60 Lens Position (R/E) Program. 6-61 Without TAG P-019 Exposure Illumination Program 6-64 Machines with TAG P-019 & BookMark 21 : Exposure Lamp Output. Value displayed is 78% of lamp root mean square voltage. 7-1 Tray Size Sensing Program 8-1 Main Drive Motor Run Program 8-2 Paper Feeder Program 8-50 Without TAG P-019 : Automated Final Actions. Go to Final Action in Service Call Procedures. 8-51 Time to Registration Switch 8-52 Time on Registration Switch 8-53 Time to Exit Switch 8-54 Time on Exit Switch 8-61 Registration Adjustment. 8-62 Bypass Feeder Program 8-99 Scan Speed / Registration Adjustment Enable 9-1 Xerographic Drive/Belt Hole Program 9-2 Transfer Corotron Program 9-3 Charge Scorotron Program 9-4 Charge Scorotron, Photo Mode Program 9-5 Dry Ink Dispenser Motor/Dispense Rate Switch Program 9-12 Copy Cartridge Counter Program W/Tag P-019 (N/A 5818 & BookMark 21) 9-14 Copy Cartridge Warranty Program (N/A 5818 & BookMark 21) 9-15 History Log of 9-14 Warranty Programs Run (N/A 5818 & BookMark 21) 9-60 CSDC Monitor Program 9-62 Exposure Adjustment Program. 9-63 BLACK Dry Ink Dispenser Program. 9-65 Lead Edge Erase (Interimage/Edge Erase Lamp Off Time adjustment Program). 9-66 Trail Edge Erase Program (Interimage/Edge Erase Lamp (On) Time adjustment Program). 9-67 Illumination Control 9-68 Side Edge Erase Program 9-69 Photoreceptor Repositioning Time. 9-73 BookMark 21 & with TAG P-019 : Extra Dispense after J1 Status Code declaration. 10-1 Exhaust Fan 10-3 Fuser Program 10-4* Fuser Drives Program 10-7 Fuser Cold Start Temperature Configuration Selection (Without TAG P-019) 10-9 Exhaust Fan Speed at Standby adjustment 10-10 BookMark 21 & with TAG P-019 : Extended Fuser Web Life 10-61 Fuser Temperature Adjustment Program. 10-63 Web Count Reset Program. 10-65 Web Count Input Program 10-99** Office Light Flicker Fix(W/ TAG P-019, 5328, BK21, XC1875, XC2675) 11-1 Sorter Program 20-1 NVM History File 20-2 Clear the NVM History File 20-3 U Codes Clearance
Input Components 1-1 Upper Assembly Interlock Switch S12 - When using Diagnostic Code [1-1], ensure that the Right Door is closed so that the Right Door Interlock Switch is actuated. 1-3 Line Frequency Check (50/60 Hz) 2-2 Control Console Switches ( Table 2) 2-5 Auditron/CVA Input 5-0 ADF Stack Force Relief Switch S51 5-2 ADF Registration Sensor Q52 5-4 ADF Ready Switch S52 5-6 Document Width Switch S53 (8 1/2) 5-10 Document Feed Sensor Q51 (Single Sheet) 5-13 Document Width Switch S54 (11) 5-15 Size Sensing Document Cover (Analog) 6-2 Scan Home Sensor Q61 6-3 Split Scan Sensor Q62 7-2 Two Tray Interlock Switch S89 8-0 Bypass Prefeed Switch S84 8-3 Registration Switch S85 8-7 Exit Switch S101 9-6 Dry Ink Cartridge Empty Sensor Q91 9-7 Copy Cartridge Counter Switch S93 (All except 5818 & BookMark 21) 9-9 Color Developer Module Switch S94 9-10 Copy Cartridge Interlock Switch S91 9-11 Right Door Interlock Switch S13 10-5 ADF Interlock Switch S55 11-2 Bin Home Switch S111 11-3 Indexing Cam Switch S113 11-5 Sorter Interlock Switch S112
Output Codes 2-1 Control Console Indicator Lamps 2-3 Copy Count Meter 2-6 Auditron/Autometer Test 5-1 Feed Clutch CL 51 5-3 Document Belt Drive Motor MOT52 5-5 Stack Force Relief Solenoid SOL 51 5-7 ADF Ready Lamp LP51 5-9 Document Feed Motor MOT51 and Feed Clutch CL 51 5-11 Document Feed Motor MOT51 6-14 Intake Fan MOT63 (High-Low Speed) 8-1* Paper Path Drive Motor MOT82 8-4 Registration Solenoid SOL 83 8-5 Takeaway Clutch CL 82 9-8 Interimage/Edge Erase Lamp 9-12** Without TAG P-019 only. Copy Cartridge Solenoid SOL 91 10-1 Exhaust Fan
*If the main drive motor fails to energize, go to the Nominal NVM Default Values tables found in ADJ 1.1 (Section 4) and check the value in 8-26, Main Drive Configuration NVM. If this value is incorrect, the 8-1 program will not operate.
** This test must be performed with the Copy Cartridge switch disconnected or the Copy Cartridge removed from the machine. This code is not applicable to 5818 and BookMark 21.
*** On 5818 with Rev. 2 software (Tag P-099) only. Not an active program in Rev. 1 versions.
