Ricoh MP C3504 Nameplate
  • ABS tect
    • Sep 2013
    • 511
    Hey all, for some reason I can't find the part number for the name plate that goes on the front cover on the machine. I can only find the part number for the front panel in the parts catalog.
    Any body have this part number? The Ricoh Logo sticker on the very front....not the model sticker. Thanks
    • 37489
    Re: Ricoh MP C3504 Nameplate
    That would be part of the labeling kit that is sent out with a new machine. To my knowledge they cannot be ordered through parts. You have three options:
    1. If you are needing to replace a damaged front cover, you should be able to remove the one from the old cover
    2. Contact whom ever it is that you order new equipment and see if they can send you one
    3. If you now someone with a Lanier or Savin dealer you might check if they have one. In the past, the Ricoh labels were packed with the manuals and driver disk by the factory in Japan. The dealer label kits were added at shipping time. I used to have a collection of "Ricoh" stickers in my junk drawer at the office.
    • anothertech
      • 1769
      I found this, looks worth a try,
      Where can I get a Ricoh Emblem or Name Plate?
      The Ricoh Brand Emblem for this model can only be obtained from Ricoh Inventory Control. To obtain a new Emblem the order number and machine serial number that you want to replace it for will be required. Please fax your request to Inventory Control at 1-973-244-2728. Inventory Control will carefully monitor the distribution of labels.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Its in the parts manual under accessories
        Regards Mark
        • ABS tect
          • Sep 2013
          • 511
          I could only find model name plate not the Ricoh logo front panel name plate under accesories.
          Anyways thanks for this information, I'll look into it! Didn't realize they control those logos so closely. Thanks!
            • 37489
            Which parts catalog do you have? The one I have is for just the C3004/C3504 and it has what I believe you are wanting unless you want the one that goes in the center of the front cover.
            • ABS tect
              • Sep 2013
              • 511
              Yes sir I want the one that goes in the center of the front cover....and I'm looking at the C3003/3503 PC but that sticker would be the same fit as I've swapped it out before.
              • FrohnB
                • Jul 2017
                • 1919
                P/N: AA001564 (RICOH) is what you want!
                We order them all the time for our wholesale machines, although we use Savin badges instead of Ricoh.
                Omertà
                • ABS tect
                  • Sep 2013
                  • 511
                  Boom that's it! You're the bomb. Thanks so much!
                  • mga
                    Copier Technician
                    • Dec 2010
                    • 1393
                    Hope this helps
                    Regards Mark
