Re: Feed tyre cleaning
I saw a machine like that at the mothership recently. They are very different than the MFDs most of us work on. The thing that looks like an ITB in the picture is actually more like typewriter ribbon, although if I understand it correctly those printers use a thermal rather than an impact process. (Heh, on the printer I saw at the mothership, the print head looked quite similar to the thermal head in the master making area of a Riso, and so if it was legal I'd bet you a cup of coffee that the print head on that printer is the most expensive part on the machine.)
That being said, I agree with the people that suggested soapy water for cleaning those rollers. The WD40 you use or any other spirit based solution are also a decent choices as well, at least if you have to worry about soapy water freezing in the winter. I would recommend avoiding alcohol based cleaning solutions if possible, but that's just my take.
