Bizhub c35
  • glasstec
    • Sep 2010
    • 25
    [CQ] Bizhub c35
    Hi all am wondering if someone could help.got a c35......2 start buttons one for colour and one for black.....am the second engineer to attend machine...fault is if you have a colour document and want to photocopy it using the colour start button it comes out gray scale...that's also with auto colour setting...if I take the same document and select full colour and copy it then it will give me a colour copy...not ideal for the customer....today I have flashed latest firmware also changed full scanner assembly and ribbon cables...fault still there...this is off the glass and through the adf....I've checked service mode incase previous engineer might of knocked a setting on,all looks as normal according to service manual..am thinking printer control board next😱 before I order incase anyone has seen this before...any help appreciated and thanks in advance😱🔫
  • HoonBoy
    • May 2011
    • 130
    Re: Bizhub c35
    Hi, my guess is that changing the auto colour sensitivity setting will solve your problem:
    Utility -> User settings -> Machine settings -> ACS Level -> put it on 4
    Good luck.
    • glasstec
      • Sep 2010
      • 25
      Re: Bizhub c35
      Thanks hoonboy I will try that thanks👍
      • copier tech
        • 8132
        Re: Bizhub c35
        I guess you have also tried doing a initialisation/Gradation adjust?
        What is the life of the IU's?
        • glasstec
          • Sep 2010
          • 25
          Re: Bizhub c35
          Cheers for the reply copier tech life on Image units sitting about 65-70 percent heading back as we speak will try a gration and and check patch sensor.thanks again mate👍
