Will be replacing a transfer belt fuse for the first time. It is on a Konica 250. Can someone tell me where the fuse is located on the unit. Is it easy to find or do I have to take a cover off? Copier is calling for the belt to be replaced. Thanks.
konica c250 transfer unit fuse replacement
Re: konica c250 transfer unit fuse replacement
I believe it is inside a plastic housing, inside the front left handle of the belt.
When doing these I dont even take the belt out, I just slide it out about 6 inches. Remove the claw assmebly (2 screws) An e clip, spring. The plastic housing is held by a very small screw.
10 min job or less. Cake. -
I believe the fuse is like .80ma... very tiny... I recently was unsuccessful with one recently on a c253.(this was a new belt would not reset) Fortunately I still had a CF card and did the PPLM mod, took care of that forever. Unfortunately you can't do the PPLM mod on the C250sComment
Weird that it would work with the c253...next time maybe try an even smaller fuse?Comment
Its the same quick blow fuse on all the C253 & C250 series machines .80mA take the long mental plate off, then look for 2 small metal contacts, the fuse is there.
Just make sure you have a tiny Philips screwdriver & the correct fuse, too high amp fuse & it can blow the MFP board.
Sometimes it wont blow first time, but simply power off & on the machine then wait.Comment
