service error kyocera fs4000
  • ivanoxi
    • May 2025
    • 22942
    You have a bad connection to the thermistor or a bad thermistor. This code is pretty specific.
    While you're checking the thermistor, make sure the surface is clean and contacting the upper roller.
    This is the part number if you need it:
    302F925650 Thermistor (FTH)
    • ivanoxi
      ok, i have another fuser, i change it the entire unit and still
      show this message on the display,
      i check out the parts manual of this printer
      and i found that the thersmitor assy is part of the fuser unit
      do you have the list of error?'
      some times shows 6030
        • 22942
        Yes, the thermistor is in the fuser, but a bad connection to the thermistor can also take place between the modular fuser connector and the engine board. Check that connection also.
        Is you're AC line voltage within specifications? Dirty or inconsistent AC can cause fuser errors. That could explain other fuser errors also.
        It's possible (but unlikely) that you may have a bad engine board or power supply.
        At least at this early stage of troubleshooting, it is not time yet to replace boards. Check out the AC first.
        • ivanoxi
          ok, thanks for the informatation tomorrow early i going to check the conectors and the power supply...
          anyways i will post the results help, to help me if i cant resolve the problem.
          • Marco_Mtz
            Call Service 6400:0000000 on FS-4000DN
            I have this error message on my Kyocera fs-4000dn could please someone tell me how to fix this problem. Thank You...
            • leroyal
              Expert on The Obsolete
              • Sep 2007
              • 156
              Call a Kyocera or CopyStar Technician.
              I know what I know better than anyone else knows what I know.
              • JustManuals
                • Jan 2006
                • 9838
                This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment
                from The Internet's largest collection of manuals
                Paul@justmanuals.com
